1/2 Kmac kit... where's this thing go exactly? pics installed?
Re: Hope this helps a little (edited)
<img src="http://images6.fotki.com/v83/photos/2/282664/1018713/tt_17-vi.jpg">
I'm at my work laptop so I can't photoshop the exact location. However, see the spring on the right? There are two "arms" running top and bottom of the spring from the wheel towards the haldex unit. The one at the top of the rear spring is the upper control arm. The run running along the bottom is the lower control arm.
Here's a picture of the control arm with K-Mac...>>
<img src="http://images5.fotki.com/v65/photos/5/58883/755653/DSCN1584-vi.jpg">
Use the tool that comes with the K-mac to remove the old bushing.
You really need to start tracking your posts...>>
Like the one from yesterday where this info was given to you...
Set that up in your "Preferences" area..<ul><li><a href="https://forums.audiworld.com/tt/msgs/1273891.phtml">https://forums.audiworld.com/tt/msgs/1273891.phtml</a</li></ul>
it goes into the inner bushing of the control arms>>>
you can have it at the upper or the lower arm (some say the upper arm gives you more adj. others says the lower)
i had my ECS adj control arm on lower
but i would put the 1/2 kmac kit up top
