2005 Audi TT suddenly blows out freon
what could be cause for freon to discharge at mass at idle
Originally Posted by Zedpalm
(Post 25104634)
Thank you for pointing out I have this in the wrong forum
Now if I can just figure out how to edit it - thank you again appreciated
Walt aka Zedpalm |
Freon is leaking out, like from the air conditioning system?
Usually freon leaks are due to physical damage (rock through the condenser), or a bad gasket at one of the hose connections. They make leak detector kits that you can add to the loop and then use a UV light to check where it is coming out. Engine speed (idle) shouldn't have anything to do with it. |
Is it discharging from the compressor by the pulley/clutch? If so, you have a bad seal. Need to replace the compressor unless you have access to the rebuilding parts. If elsewhere, use standard automotive air conditioning system troubleshooting techniques to find and repair the leak.
Originally Posted by Mister Bally
(Post 25105193)
