2005 TTR Electrical issues
Hey guys. I just picked up a new (to me) 2005 TT Roadster, and there seems to be an electrical issue.
I have no front or rear parking (side) lights, no radio lights and I have no lights in my instrument cluster (except the needles). This is odd because my brake lights work (same bulbs as the side/parking lights)
I have searched and read through dozens of threads of people with similar (but not the same) issues, but I have not been able to resolve mine.
I have checked literally every fuse, I have replaced all 4 bulbs (front and back), I even replaced the headlight switch but I still cant figure out what is going on. Nothing has worked.
Any ideas/suggestions would be great! Thanks in advance!
An oddball idea here, but check the grounding points and a grounding strap if there is one. My Mk.4 Golf started having weird electrical problems, blew both headlight bulbs and just quirky electrical gremlins. Had me and my mechanic scratching our heads. My mechanic finally traced it to the grounding strap corroding from the inside out. Looked fine on the outside, but green w/ corrosion on the inside. Once that was replaced, car ran perfectly. Could be that one of the grounding points may not have a good contact. If you are going to check and clean them, use dielectric grease to seal the contact from air/moisture.
'81 tic-tac
01-17-2004 02:46 PM
