3rd and Final post...Just installed forge optimus DV..... any tips on tuning it ?
Had it all the way down last night and it seemed to flutter. So I gradually turned it tighter (towards +) at some point when too tight felt like I had less power boost did not hit as hard so I backed it off and it feels better ?
Does that sound right ?
Well....>>
Tightening it up won't get you more power unless you were leaking boost. I found that green spring, 8 cliks from soft would hold 22PSI just fine. I'm running the yellow spring and full soft (pretty similar to green at full hard). Performance and boost hold is great, but I still have some flutter. Can't get rid of it...
Thanks..
Mine did not come with springs so I assume I have the green spring. It does make a weird flutter noise when I let off the gas. I am not chipped only have intake and neuspeed exhaust.
When I had it turned up tight the car felt like boost built more slowly, did not hit or pull as hard. When i loosed it it seems to pull quicker.
