440 cc injectors with VR6 MAF housing?
I noticed this while digging around on ECS' website. They say "Customers have had good sucess combining these injectors with VR6 MAF housings with stock or standard chipped programming".
I haven't seen this discussed on here before. Any thoughts? Does the VR6 housing provide much more flow?
right, but i didn't know if the **** was at the its max diameter for benefit...
or if you could run a larger id and run a higher fuel pressure. but if you don't actually flow more air than it wouldn't make sense.
No...You can't..>
really run a larger ID. As the ID increases, the MAF signal is reduced. After a certain point, no matter what the fuel pressure, The ECU will interpret the data poorly and not provide proper info to the injectors. We have a load based system that's taking data from a lot of sources...It's not purely dependent on just air and fuel for the proper calculations..
