6 speed transmission problem after warm up and engine vibration
I have a similar problem as the post below. My transmission shifts rough after the car gets warm up along with engine vibration that feels like something is loose. Does anyone else experience this?
'01 225 Quattro<ul><li><a href="https://forums.audiworld.com/tt/msgs/1638828.phtml">https://forums.audiworld.com/tt/msgs/1638828.phtml</a</li></ul> |
Many are finding it's time...>>
To start replacing engine mounts. They get sloppy and shifting precision will deteriorate as well as contribute to more vibration.
I would stay with the stock mounts (engine and tranny) unless you are highly modded...>>
and then I would look at the 034 Motorsport's rubber mounts.
If you have the stock dog bone mount, change out the rear rubber insert with the Energy suspension insert. |
True. Just replaced mine 2 weeks ago, 153K miles and it "crisped" things back up.
Re: I would stay with the stock mounts (engine and tranny) unless you are highly modded...>>
Are you guys saying that the mounts affect how the gear works? My gears are hard to engage after about 20 minutes of driving.
No, the stiffness of new mounts just eliminates some of the "slop" that is a result of worn mounts.
Your issue sounds completely unrelated to worn engine mounts, but rather something heat related in the transmission, such as transmission fluid level/condition.
Something else going on then...As mentioned by SparTTan, try a fluid change...>
Redline Mt-90 is a good choice..
Re: No, the stiffness of new mounts just eliminates some of the "slop" that is a result of worn moun
That would explain the rough gear shifting. However, all this begin with engine vibration. Does this mean I have two separate problems that coincidentally started at the same time or an entirely different problem?
