About to go nuts with this wiring...No one knows color of wire for the parking lights???
not sure what year your TT is
But the wiring diagram for my 2001 TTQ shows the parking light wires as grey/black...hope this helps, if you tell be the year of your car I can double check.
Mine is a 2002 TTR thanks for any help...The problem Im having is this...
<center><img src="http://pictureposter.audiworld.com/70355/dscf1806.jpg"></center><p>I have a relay system made by torquesteer. The red arrows pointing to wires go to the light boxes x2. The purple arrows go wires leading to battery. Black arrow is suppose to connect to parking light to complete the circuit and turn eyes on. Problem is when connecting wires to battery and boxes I have attempted to access parking lights using only this single clamp (black arrow). When attempting to tap into the wires for parking lights the boxes come on but do not turn off when turning the parking lights off. Im not sure if there should be more than one wire taping into the parking lights?? Secondly I didnt know if there is a way to have a switch inside the cabin to turn eyes without having to rely on parking light switch with using this wiring system?
Re: Mine is a 2002 TTR thanks for any help...The problem Im having is this...
The way I do my angle light is easy.
Since u have to open the headlight to put in the "angle eyes", you have access to the parking light from inside.
simply weld two wire the connection instead figuring out wich line if for parking light, and lead thow two wires out to what ever you need to do with it.
NJRoadFan
05-11-2007 07:58 PM
mmart6545
11-09-2004 03:54 PM
20valvevermont
08-25-2002 07:29 PM
to wire city lights, do u wire them up to parking lights or to the old fog light switch on a 97?????
yellowsub
06-02-2002 08:35 AM
