Adapting BMW wheels to TT? Possible? Experiences?
I have a line on a very inexpensive set of Fikse Mach V's with 45mm offset for an M3. Are spacers all I need to change this to the TT 100mm offset? What's the trade-off, if any? I would be using these particular rims for autocross, so I predict higher than normal stress factors. Does that make a difference with spacers?
Any advice appreciated!
david
david
Here's the list of H&R adapters....Unfortunately...>>
It does not look like they go from 5/120 (BMW) to 5/100 Audi TT. There are some companies that make custom adapters though. Unfortunately, to keep your same 32 offset, you'll have to find adapters 13mm thick (45-32=13). Most adapters will be at least 25mm thick (like the H&R spacers for the TT) resulting in a true offset of +12mm. This will work fine (many of us have gone to 15's with no problems on the front) front and rear if you can source them.......<ul><li><a href="http://www.ecstuning.com/wheelspacerkitpage.htm">ECS tuning, adapter page</a></li></ul>
Nepok
08-02-2005 07:08 AM
ttuner333
24
06-17-2005 08:35 PM
jayel
Wheels & Tires Discussion
09-16-2004 02:36 PM
HACK THS
01-12-2004 05:57 AM
