after run coolant pump
01 225: my after run coolant pump is not working. Any ideas on where to start? Is it always the coolant pump that goes or should I look elsewhere first?
also, thanks to all those who contribute to the FAQ page.
hows the AC and the radiator fans?
I had a bad fuse connection in the box on the top of the battery, and my after run coolant pump, AC compressor, and radiator fans stopped working. I would definately notice the other two not working first in Texas, but if its cold enough where you are, you might not have. So check those, cause it could be as simple as a rusty fuse bottom.
Jaster
10-03-2007 06:18 AM
2000audis4ny
02-27-2007 11:58 AM
TTransport
08-27-2006 11:51 AM
TTS_4_to_A6
9
12-12-2001 10:19 AM
