air vent ring exhaust tip MOD question ?
Old 05-20-2002, 03:42 PM
New Member
silver arrow's Avatar
Default air vent ring exhaust tip MOD question ?
my exhaust tips are 70mm wide, is this enough to fit the air vent rings into ????????
Old 05-20-2002, 03:47 PM
Member
hoTTub's Avatar
Default Schwing does it again, =) I think he said they *snapped* right in
on the 90mm, My guess is that you would have to modify it to the point where it would be alot of work. I will let him tell ya for sure tho'
I think you should leave yours as is, I like the twin *pipes* sticking out from the center...I like that has the *just pipes, no fancy tips* look about em'. I would leave 'em
Old 05-20-2002, 03:50 PM
AudiWorld Uber User
TTschwing's Avatar
Default These are on 90mm tips....>>
<center><img src="http://images.fotki.com/v3/photos/7/7305/111401/DSCF0096-vi.jpg?1021423032"></center><p>Don't know mark. The inside measurement, inner Lip to Inner lip (not hole diameter) is 70mm so they might fit quite well actually. Hit my Fotki link below and go to Mis. Mods to see a pic of the inside of the ring...
Old 05-20-2002, 03:57 PM
AudiWorld Uber User
TTschwing's Avatar
Default Here's the inside shot.....>>
<center><img src="http://images.fotki.com/v4/photos/7/7305/111401/DSCF0099-vi.jpg?1021425545"></center><p>
The thin lip measures 70mm (ID) across.....
Old 05-20-2002, 03:59 PM
Member
hoTTub's Avatar
So it might fit the inside but would the outside lip be flush?
Old 05-20-2002, 04:03 PM
AudiWorld Uber User
TTschwing's Avatar
Default Looks like it would slide right over a 70 mm tip....>>
(inside of the ring lip)....Leaving it look like the pipes are bigger than they are....Actual hole diameter is 60mm......same as a 2 3/8 boost gauge....hmmmm.....
slinett
Audi A3 / S3 / RS 3
12-23-2006 07:23 PM
tmS4cab
05-31-2004 06:10 PM
clean.
05-13-2003 07:36 PM
TTschwing
34
05-14-2002 07:37 PM
LJ.925
04-30-2002 10:03 PM
Quick Reply: air vent ring exhaust tip MOD question ?
