Alignment
Have an 02 tt quattro that has been lowered,(i didn't lower it)can it be aligned or do i have to raise back up to stock? Eating tires and no suspension parts fit....
Does it have adjustable lower control arms at rear? Lowering increases negative caster and affects toe. Toe is adjustable at trailing arm mounts. ( slotted holes). Camber is not adjustable without adding adjustable control arms which also help with toe. Front will align fine without aftermarket parts. These cars do require a good alignment tech. How much is it lowered? One inch or so is ok and feels good. More than that is counterproductive.
Search alignment posts in this forum. Subject has been discussed many many times over the years. Good luck! |
