For all of those concerned with their Air/Fuel mixtures on the dyno....
What APR told you about the A/F ratios is ABSOLUTELY true! When you are using a tailpipe sniffer, it is very innacurate for *real* a/f ratios for tuning or analyzing. The only true way to get a reading is to drill a hole in the downpipe and weld a bung (no Beavis jokes) for an O2 sensor that is similar to the stock but is much more sensitive and samples more often....
Anyone looking for real #'s or one off tuning MUST get one of these bungs welded in, there are a few places that have dynos that will not even put your car on unless you have this done.
So relax, your A/F ratios are probably not as bad as you think.
no.....not really
even a A/F ratio gauge is only as accurate as the o2 sensor it is getting the reading from....A/F is good for full throttle rich/lean reading but not for *EXACT* ratios. As far as I know, the only way to get true readings are by the way I mentioned.
hmmm.... not off hand but heres an idea!!
we are going to bring my boyfriends Nova down to be dyno'd here within the month....
His car is fitted with speed-pro fuel injection with a wide band O2 mounted in the correct location. We can hook up the laptop and monitor the A/F ratio off the wide band and compare it to the tailpipe reading taken by the sniffer for you guys.
