Another offset wheel question..
if I get some H&R 25mm wheel spacers will I be at least at the stock offset? Im thinking 42mm - 32mm = 10mm difference. Plus the .5 inch between my 17x7 and the stock 17x7.5, should get me near stock offset right??
Front Wheel
14mm inside fender (stock is 22.7mm inside)
Rear Wheel
20.5mm inside fender (stock is 28.7mm inside)<ul><li><a href="http://www.ezaccessory.com/SearchResults.asp">Don't forget LONG lugbolts</a></li></ul>
I've got 19X8 wheels with a 35et.
The calculator says I need 19mm front and 25mm rear spacers.
copied from above:
"additional data collecting has shown ET22 front, ET16 rear to be a safe FLUSH setup"
Does this sound right? will I fall in the "safe" range? unless I'm doing something wrong.... wheel offset and spacers would be ET16 Front and ET10 Rear?
