Another quick q about a chip
Old 10-13-2007, 10:58 PM
RemixTT's Avatar
Default Another quick q about a chip
I was looking at this chip on ebay as opposed to getting like an APR. It's much cheaper, but i notice on the 225 it only has 252hp after the mod, whereas with the APR, it claims about 270. Is this still a good chip for the price? What should I do?<ul><li><a href="http://cgi.ebay.com/ebaymotors/Performance-Chip-for-Audi-TT_W0QQitemZ250174193674QQihZ015QQcategoryZ33597QQ ssPageNameZWDVWQQrdZ1QQcmdZViewItem">Ebay chip</a></li></ul>
Old 10-14-2007, 12:22 AM
DynomiteTT's Avatar
i stay away from that, get chipped locally or go MTM if you have none close
Old 10-14-2007, 04:16 AM
blackfnTTruck's Avatar
Default Well....you are going to have to pull your ECU, remove the chip, probably soldered......
in, then solder in the performance chip. If you've never soldered before, I would pass. If something goes wrong you have nothing to fall back on. They will probably replace the chip, but if a problem arises with your ECU you are out of luck. If you are still under warranty, that would be voided once you break the seal on your ECU. Go with a flash.
Old 10-14-2007, 04:37 AM
JustAdam's Avatar
2nd!
Old 10-14-2007, 05:59 AM
MCPaudiTT - DEFCON 1's Avatar
I would avoid that like the plague.... Save up and do it right.
Old 10-14-2007, 07:34 AM
|everso!|'s Avatar
err...AVOID.
Old 10-14-2007, 07:49 AM
roadyTT's Avatar
You get what you pay for
Old 10-14-2007, 07:52 AM
AudiWorld Awesome User
InTTruder's Avatar
Default Back away from eBay. Get the good stuff.....
Revo, MTM, GIAC, APR: solid performers with a huge development program.
Old 10-14-2007, 08:30 AM
coasTTal's Avatar
Default Only have it chipped by someone local. Should you have a problem, then you have someone
to go to. All the chips, APR, Revo, GIAC, etc. are all abou the same so I would go with whoever is local and reps one of those.
For me. I have the APR chip in my 01 225 and now have about 85K on it without any issues.
Old 10-14-2007, 08:48 AM
New Member
teeva33's Avatar
Default Re: 2nd!
Where did u get clear side headlight and angel eyes? I want!!!!!
Quick Reply: Another quick q about a chip
