Anyone ever get a ticking or clicking sound from timing belt tensioner or the water pump?
I've been trying to track down an intermittent loud clicking sound that I get. I haven't noted any pattern in when this occurs, driving conditions, temperature, etc, it just comes and goes. Thought it might be valve noise, potentially from oil starvation but had a new oil pump installed last week and I still get the noise. Definitely related to engine speed, not wheel speed, and more likely to happen with heavier load on the engine, so wide throttle, low RPM type situations.
I pulled the timing belt cover and it doesn't look like anything is interfering with the belt itself. Have also ruled out axle/driveshaft issues because it is depended on engine RPM not vehicle speed.
Thanks!
Thanks!
I've got what seems to be lifter noise too but that is much quieter
like a background noise, this ticking is louder than that and a slower frequency. The valve noise is more of a fast ticketa-ticketa-ticketa where this is a tick-tick-tick. I gotta record it next time it happens.
Jump under the hood while Danielle drives!!! Like that rally car co-driver did ;)
Probably not helping much more then stirring the pot. If you need an extra hand at all call me and I'll be right over.
Timng chain tensioner??
For the chain that links the cams. Listen on the drivers side of the valve cover.. There have Been a few failures that I've seen here and in person....
