Audi TT: ESP light won't turn off
Run (or drive), don't walk to your nearest dealer.
This is the first thing that went bad on my TT at about 4k miles. I think they called it the Haldex control module that had gone bad. This is bolted to the Haldex body and runs about $800, so I hope your car is still under warranty. It could be a number of things but this was what was causing my ESP light to continually stay on. If you don't want to go to the dealer you could find someone with a Vag tool and see what type of fault codes it is throwing. Good luck. -Doug
Yeah, it'll throw a code in the Mark 60 control...>>
module telling you that there's a code in the engine control module. A disconnected MAF doesn't light the CEL all the time, I guess this is a way to get your attention.
In any event, you need to get the DTC's out of both control modules.
BTW, re-connecting the MAF won't instantly get the ESP light to go out. Takes at least two starts to get it to happen.
Check the fault codes
I had the same thing. The ESP light would come on a few seconds after starting the car and stay that way all the time. The fault codes detected meant the ESP sensors were not communicating with the ECU.
I had the ECU replaced at a fraction of the cost as a semi-guarantee treat by the dealer. Paid $200 instead of the $900 list price. We are offered just a one-year warranty here in Mexico.
Re: Run (or drive), don't walk to your nearest dealer.
Yep, same here. Just put it in yesterday and now I'm waiting for the Haldex module. I had a strange binding in the rear wheels at low speeds; feels like running over a rock. Service guy says probably related, but I'm not so sure.
BC2885
04-16-2008 05:24 PM
Captain Sheetmetal
07-16-2004 08:02 AM
o2bnme
11-24-2000 10:56 AM
