Audi tt roadster 2002- Faul code P0411
Was that with a VAGCOM or generic reader? Do you hear it spool down after you shut the engine off? I'm having this code periodically, but also fuel trim fault, and a boost fault which tells me I have a leak. I can hear my SAI spool down if I am paying attention.
Also, it is a 225 tt or the 180? There are a lot of differences between the 2 that might behoove you to post on the tt forum.
So just to make sure I understand, the SAI does take air from the uncharged side of the intake. Is that the long plastic pipe you are referring to? I assumed if you had an intake side problem beyond that long pipe, it may manifest itself in an SAI fault.
you have prompted me to go look at my longitudinally installed 1.8 in my A4...
Audi Other Audi Coupe 1993
EvaldasR
09-25-2016 12:41 PM
Enzo
10-26-1998 10:10 AM
