Bad Instrument Cluster
My temp gauge isn't working correctly and is pegged all the way to the right. I had the car checked and it's running at the right temperature, but the gauge is reading wrong. All of the other gauges are working fine. I was quoted a cost of replacing the instrument cluster at $1000-.
Someone on another board asked if I had the timing belt replaced recently, which I have. As a matter of fact the gauge problem started the day my timing belt was replaced. The other poster suggested that my thermostat may have gone bad. That would be welcome news as I'm hoping that I don't need to spend $1000- to take care of the problem, but if it was my thermostat it seems like my car would be overheating.
Any thoughts or comments on this? Thanks!!
It may be the temp sensor rather than the thermostat...it's on top along the left side of the engine
<center><img src="http://images2.fotki.com/v332/photos/4/419847/3485849/Tempsensor-vi.jpg"></center><p>Check the connection, if that isn't it, change the sensor.
Cause>>>>effect.....????....>>
Did you take it back to the guys that did the job? Could be a thermostat, could be an air bubble in the coolant lines, Could be a temp sensor. Check the actual temps with the HVAC controls...Details in the FAQ..
Re: Cause>>>>effect.....????....>>
I just did a search using the words "instrument cluster" and apparantly there is a class action lawsuit against Audi for this problem.
http://www.classcounsel.com/news/audi.html
I'm hoping it's one of the other issues that you guys mentioned above. Thanks!
It's not your thermostat or your temp sensor or your timing belt
If your car is running at the right temp your thermostat is doing its job, and if the AC display shows something between 90 and 100 celcius then your temp sensor can't be what's driving the cluster to peg its needle.
BTW, my cluster started doing this exact same thing (1 notch below max at operating temp and middle of the gauge at cold start) within 1 week of my timing belt and water pump and thermostat and temp sensor replacement. Except that my cluster started doing this BEFORE all of the above were replaced. Replacing them all did nothing to fix the cluster. Welcome to the club.
Re: It's not your thermostat or your temp sensor or your timing belt
133T,
so are you saying that it is the cluster? I contacted the law firm that is representing Audi owners in the class action law suit. If it is the cluster than I will add my name to that law suit.
No, He's not saying that..>
Have you checked any of the other ideas suggested? Check the Temps with the HVAC controls first.<ul><li><a href="http://www.wak-tt.com/climate/climatecodes.htm">Check the temp yourself....</a></li></ul>
hAUDIni
17
11-25-2004 01:16 PM
TTeleven
12
03-01-2003 09:43 AM
