Battery replacement question
Old Feb 8, 2006 | 01:52 PM
milobliTTz's Avatar
New Member
Default Battery replacement question
Is there any special trick to replacing the TT battery? i.e.: will it zero out the computer or the key fobs or anything like that if I just do a quick swap out/in? Additionally, does anyone have any recommendations on batteries?
Old Feb 8, 2006 | 02:48 PM
GeTT da NeTT's Avatar
Default Several hear run Orbital, but there is a problen with the optimal install (lots of info in the
forum using the search function). You should be fine if you swap it out, but you might need to recode the radio, which can be a pita. I use a good quality battery from Walmart.
When I swap batteries, I use a 12v power supply plugged into the cigarette lighter. You could do the same thing with a 12 v battery.
Old Feb 8, 2006 | 03:13 PM
TT_Nuge's Avatar
Senior Member
Orbital? I think you mean Optima ;-)
Old Feb 8, 2006 | 04:22 PM
kodeTT's Avatar
Elder Member
he's probably already thinking about that orbital polisher for spring cleaning.
Old Feb 8, 2006 | 06:07 PM
That damn Dan's Avatar
Nah, He's the NASA guy remember? He's got "orbital" on the brain =)
Old Feb 9, 2006 | 02:06 PM
mobsTTa's Avatar
Default Optima 35 is the direct replacement
Try interstate battery store locations. Difficult to find. For keeping power see a few posts ^
Yang L
Q7 MKII Discussion
Feb 22, 2019 06:04 PM
achow26
Q7 MK 1 Discussion
10
Feb 20, 2013 05:12 AM
Audifan1
15
Nov 13, 2008 10:28 PM
prtdvl
Dec 30, 2002 02:51 PM
