Which BBK's will fit behind flik wasps 18 x 7.5 with a 33 offset and 15mm front spacer?
Re: Which BBK's will fit behind flik wasps 18 x 7.5 with a 33 offset and 15mm front spacer?
I've found that these wheels SUCK for fitting big brakes without at least a 15mm spacer. Right now I am running a setup that I built which is about equivalent to ECS stage 2v2, and I have about 4-5mm of additional clearance for larger calipers. I think you'd do fine with just about any stock Porsche caliper except the huge ones like the Cayenne. Beyond that, I believe that the Wilwood calipers are tiny in comparison, and would be a breeze to fit. I seem to remember that Stoptech calipers are not that larger either....
I was actually worried when I got my 15mm's, because without any spacer, the wheel would hit the caliper way before it even came close to seating on the hub.
Jesse S.
06-23-2008 12:36 PM
beejohn
02-09-2008 07:22 PM
kjb99
06-15-2007 02:06 PM
boostinmr2
11
02-10-2005 10:15 PM
