Blinker Housing Plastic Clip Broken
<center><img src="http://pictureposter.audiworld.com/108703/audi_11_12_06_003.jpg"></center><p>I need help on finding parts and how to install blinker light housing unit. There is a plastic clip that is broken all else works. Any suggestions?
If you want a cheap fix, put a couple small dabs of caulk on the back and stick it back on.
Otherwise buy a new one, and put it in...
mine did the same, I used a little bit of epoxy, works so far
Couple of dabs of clear silicone is holding one of mine on..>>
for a couple of years now Easily removable if you need to.....
new housings are only a couple bucks.
Double sided tape...
That is what I used on mine. Works fine.
