Blinkers stopped blinking...>>>
The blinkers would blink only once or twice and would stop completely. Could this be the flasher relay or something else? If so where exactly is it? TIA
Flasher relay.
Hazard switch. Got it at WorldImpex.com
its like 53 bucks.
Run it to your local best buy, they should pop your stereo out for free if they are nice..
Then you just pull the plastic plate down above the stereo, unsnap the little rail that holds the buttons in pull the hazard switch out, reconnect, put the plastic plate back in, push the stereo back in.
Make sure you have your radio code if you disconnect the stereo.
Good luck.
its like 53 bucks.
Good luck.
awdinut
04-13-2018 03:52 PM
black225TT
05-22-2003 11:49 PM
