BMC-CDA: Went to HomeDepot and bought these 4 metal sheets and
<center><img src="http://pictureposter.audiworld.com/24713/mvc-029f.jpg"></center><p>this Flexible Aluminum Hose. I am going to try to connect the Aluminum hose to the CDA and since its flexible(not like the metal non-flexible one included) I want it to go all the way down to the bottom of the side of the wheel. Now, Does anybody know(people that have a CDA) if the aluminum hose goes all the way down the little duct? or are there some abstructions in there?
Thanks!!
Thanks!!
You should talk to Sean (Hottub)
I assume you have a 180... You'll have a great deal of difficulty getting that "flexible" duct to work.
You'll need a plastic flex hose (or hoses). There is virtually no room under the fender liner.
Unfortunately, what you have WILL NEVER fit without alot of
trimming.
I was able to fit flexible carbuerator hose that had a diameter of about 2" and I still needed to trim some of the metal.
You're going to have to....>>>
<center><img src="http://images.fotki.com/v3/photos/7/7305/103470/DSCF0074-or.jpg"></center><p>Run it inside, down below the headlight. There's not enough room between the fender liner and the wheel well to do this.....
So, its not as easy as it looks in this picture I found in the forum, i think its your car,
<center><img src="http://pictureposter.audiworld.com/24713/tt_w5.jpg"></center><p>This looks prety simple, just run the thing down, no?
yeah that is my car but notice that the hose is just dangling there.....
and is not hooked up to anything. Notice that the fender liner is not in place, which is the part that interferes with the hose routing.
a6wrenchin
10
10-14-2015 07:10 PM
RedDragoN750
Audi 100 / A6 (C4 Platform)
01-28-2008 05:27 AM
AWD2KS4
15
01-27-2008 01:01 PM
Carlo5555
08-19-2007 06:10 PM
FriscoTT
9
10-16-2003 03:01 PM
