Boost Machine Question, pref. giac guys
As of now, Ive got 5.5 turns on the boost, and running 18 psi. with 1 turn on the onset, what do you guys find out is a decent set up on the onset?
i dont mind it being a lil aggressive.
Goin to go try 6 turns on the boost see if it peaks around 22psi.
Crank the onset up...>
Just a little.....You'll feel the valve start to get slightly snug at around 1.5 turns. This seems to be the best spot for smooth onset and transition. Giac takes a sensitive touch on the regulator to find just the right spot. Inch it up slowly until you've got it right. Overshoot and it won't run so good. For some reason the threshhold with Giac is a very narrow window of adjustment..
Bruno_S4
05-08-2007 09:56 AM
exS4||wp0ZZZ
07-13-2006 01:39 PM
B5QShip
07-15-2005 05:38 AM
QuattroRocket
09-14-2003 07:45 PM
