Boost problem!
Old Jan 27, 2007 | 07:57 AM
  #11
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Worth a shot...>
A lot of times, when you increase flow (like you just did with the DP) it will throw a MAF over the edge..
  #12
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
That's fine then...Same place as mine..
Old Jan 27, 2007 | 07:58 AM
  #13
Lowcountry's Avatar
Copy that. Thanks, Steve.
Old Jan 27, 2007 | 09:01 AM
  #14
Lowcountry's Avatar
Default Ok, Reset ECU, disconnected MAF, problem still there.
I don't think it's the temp sensor, though. Last time that went bad on my car, I had fluctuating rpm at idle, black smoke, and sputtering during gear change. I'm not having any of that this time. If my problem were related to the coil packs, wouldn't I be getting some sort of codes? The codes I've thrown today so far have been: p1602 power supply B+ terminal 30 low voltage.. I cleaned my battery terminals which had slight corrosion, reset codes, and this one didn't come back. The other was p0102 maf circuit low input, obviously due to MAF being disconnected. Reconnected and cleared and this code did not come back.
So, any other ideas?
Old Jan 27, 2007 | 11:05 AM
  #15
Lowcountry's Avatar
Default No joy.
So nothing has worked. I even put the OEM DV back in there, but no dice. Guess I'll be taking it in.
Old Jan 27, 2007 | 05:28 PM
  #16
kodeTT's Avatar
Elder Member
Default did you check the hoses under the battery tray? that's a common hose leak after doing a FMIC
and sometimes, those clamps aren't tightened down as well as they should be.
Old Jan 28, 2007 | 05:24 AM
  #17
petervan's Avatar
Member
Default that sharp venting of air doesn't sound like a leak, more like system is cutting your boost, >
sensing something isn't right and protecting the motor.
Again...I may (probably) be wrong, but check for ignition retard from knock
Old Jan 28, 2007 | 07:38 AM
  #18
Lowcountry's Avatar
FMIC went in 9 months ago... sound is coming from BM/DV/N75 area.
Old Jan 28, 2007 | 08:10 AM
  #19
Lowcountry's Avatar
How would I check for ignition retard? Put it on the vagcom?
Old Jan 28, 2007 | 04:14 PM
  #20
petervan's Avatar
Member
yes....while driving, when yu get the venting see what the cylinder retard values are
PracTTical
Sep 28, 2008 07:16 PM
econnelle
May 16, 2008 07:00 PM
HdiaS4
30
Feb 12, 2008 06:47 AM
ski ya later
May 12, 2006 12:08 PM
Alias Unknown
Jul 5, 2004 09:30 AM
