Boost testing done
Old Feb 3, 2005 | 11:15 PM
DoomWeasel's Avatar
Junior Member
Default Boost testing done
I have a 225QR with an APR chip. It seems that I am getting about 11psi in stock setting and 14 psi in chipped mode. From yesterday, these sound low, and I should be around 15 and 19 respectively.
Does it sound like I have a boost leak? Where should I start looking for leaks?
Old Feb 4, 2005 | 12:06 AM
yoonskim's Avatar
Default Re: Boost testing done
Wow I spike to about 20 and hold at around 17 on my VW GTI 1.8T with APR chip. You must have a boost leak.
Check the hose right before the IC you might have a clamp that's loose or the hose that's actually off. Check that and also the rubber pressure hose on the turbo which might be loose as well.
did this happen to you for a while? or once? limp mode? i don't have a TT YET so i don't know for sure but considering the same engine, i think i'm guiding you to the right direction?
Old Feb 4, 2005 | 12:36 AM
DoomWeasel's Avatar
Junior Member
Default No... it is definitely not limp
I just got it back from the dealer today. Any limp mode would have been cleared. I just installed the boost gauge, so I am not sure how long it has been going on. Let's just say that I was suspecting there was a leak, since I didn't really feel too much difference between stock and chipped programs.
Thanks for the tips though
Old Feb 4, 2005 | 01:37 AM
TT-Hombre's Avatar
Junior Member
Default Check out my recent posting about my low boost
It turned to be a bad/failing MAF sensor. All is very well now ... with my APR, new MAF, hyperboost DV and dieselgeek short shift.
I also thought it was a boost leak.
Old Feb 4, 2005 | 07:16 AM
maaliish's Avatar
Default My car holds at around 15 with APR93 on colder days. The only time it boosts to 20 consistently is
in the summer.
Old Feb 4, 2005 | 11:02 AM
DoomWeasel's Avatar
Junior Member
I am in CA..... does +65 F count as cold weather?
Old Feb 4, 2005 | 12:22 PM
DoomWeasel's Avatar
Junior Member
Default Interesting....
I have a hyperboost too.... do you have a link to your post? I can't seem to find it in the search. Thanks for the thought.
Old Feb 4, 2005 | 01:36 PM
TT-Hombre's Avatar
Junior Member
Default Actually ... I had a number of related postings
Do a search of "hombre" in the TT forum and for just the last month. You will find a number of posts and responses.
If it was just one post, I'd give you the link ... but you should check it all out.
Good luck ... and keep the faith. Mine's running great now.
tydawg09
Aug 19, 2010 05:26 PM
Sloooo4esT
Audi Original "S" Cars
15
Aug 28, 2006 02:59 PM
tfosorcim
Jun 23, 2004 08:13 AM
NeverEnough
Nov 21, 2003 08:17 AM
Jay^Jay
May 20, 2003 08:30 AM
