Calling TT Guru ???
Calling TT Guru ???
Throwing 17965 Overboost and 17705 Connection to throttle valve pressure dropped looking for loose hose can't find one unless I look at FMIC and have to take bumper off----CRAP--- Where to look harder first?
Overboosts are rarely caused by hose leaks.....>>
Unless it's the little one from the N75 to the wastegate. Clear the codes and see if they come back. Might have just been a transient error. Lots have been getting them n this heat..
nope. but like Steve says...rarely an overboost is a loose hose...in fact
its just the opposite...you will not get any boost once you lose a hose...you will lose so much pressure from that, your turbo will not spool up at all.
5-8 psi is limp mode that the ECU put the car in. a hose that disconnects
from, lets say a DV...you will not be able to boost at all...the air just leaks into the atmosphere, not into the DV.
MC Hammered
09-15-2006 08:35 PM
S4-Fireblade
Audi Original "S" Cars
09-20-2005 03:46 PM
