This car is a mess. 2001 TT 225. Still no start after cluth job. codes inside.
After doing a test fire with the clutch not bled and exhaust off, I removed the battery, coincidentally the positive and negative terminals touched. I buttoned everything thing up and now no start. Pulled 8 codes The car is a plethora of problems to begin with but what would cause a no-start?
8 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-00 - -
18011 - Internal Control Module: Failed Self-Test
P1603 - 35-10 - - - Intermittent
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
From the codes, I see the immobilizer would cause a no-start issue. Has anyone effectively deleted this immobilizer? I've searched and seen talk of it. After deleting all the codes, tried to restart the car. No go. Codes did not immediately return. Haven't checked recently. Any help would be great b/c I'm running in circles trying to get this thing back on the road.
8 Faults Found:
P1602 - 35-00 - -
Immobilizer clearance is required for the ECU to allow a start -->
This is a combination of the instrument cluster and the ECU. Your accidental discharge could have fried enough of the cluster or ECU to keep the immobilizer from allowing a start.
This is an area that is PIN protected (i.e. all the proceedures to adapt a cluster/ECU require a PIN obtained from Audi) so you are pretty much SOL without an Audi tech.
Bad news though... 18011 means a bad ECU. I think you fried a lot with that discharge.
old audi's blow fuses before they blow an ECM. Are you telling me my ECM is out?
But i've also tried starting a car with a bad ECM and it'll just turn over without firing. This is not even turning over. This car is a piece. I'm just glad the owner got it for cheap but .. she's paying for it now.
lol you dig into a car, fry the ecu and you blame it on the car? Maybe some responsibility
is in order. You're the one who fried it ;-)
I just hope that you simply wiped out the immo data and didn't damage the cluster/ecu.
Tons of clutch jobs have been documented on this forum and no one managed to fry anything in the process. Fuse doesn't always help in these situations.
Yep, if you get no crank, fried ECM + more -->
It wasn't clear that you had no crank, you said no start. But...
It goes this way... immobilizer in the cluster examines the key, CAN bus communications go to both the central locking system and the ECM. Central locking system has relay control of the starter through "starting interlock" relay (#5) on the micro relay panel that has 6 relays. That's not happening, meaning somewhere along that communications path, things are not working.
Your codes indicate that that you fried several control modules. This is very likely with the short you experienced. No fuse is going to be fast enough to blow on the transceivers for the CAN bus in the modules.
Compared to your older Audi's (and mine), these cars are basically a sophisticated network of computers. You simply discharged a bunch of capacitors in several modules through the output stage. Very expensive to repair now.
Sorry, but I think that's the score in this case.
MarTT
VAG-COM Discussion
07-25-2003 04:05 AM
