Changing DSG oil on 3.2 ** does bevel box oil need changing?
Hi all,
Almost done with maintenance on my newly aquired 04 TT 3.2 with 64K miles. I've done fuel filter, haldex oil/filter, rear diff oil, air filter, brake fluid, spark plugs and green coolant sensor (yeah I've been busy). I plan on keeping TT at least 5 years, and want to be down to only needing oil changes.
I ordered DSG oil change kit from ECS, got the 6262 tool coming from someother place.
While down there, I want to change the bevel box oil, but I was under there today and couldn't see the fill hole. I think I need to remove the heat shield. I also can't find what oil to use, the bentley says it's lifetime fluid, and it only shows rear diff on fluid chart. What oil should I use? Or should I just leave it alone? My rear diff had some metal shavings and was rather dark / the plug had black residue --it said it was lifetime fluid.
Thanks.
Thanks.
I just changed the DSG oil by draining and filling from the single hole >>>
at bottom of the trans. Remember, you need the VAG-COM to correctly measure the level of the oil after filling.
<img src="http://images30.fotki.com/v479/photos/1/1128101/4984597/oilchange1-vi.jpg" />
<img src="http://images28.fotki.com/v1000/photos/1/1128101/4984597/oilchange2-vi.jpg" />
Re: I just changed the DSG oil by draining and filling from the single hole >>>
Yah, I'm pretty sure I can handle the DSG oil change...only problem I see is keeping the car level...
My question was about the bevel box, which holds .9 litres but not sure about the oil. It a small box right behind the DSG.
It was actually the transmission/bevel box. It is much better now that I put
another 1.3 l of fluid in, but I think I did some damage, as it is still there. I may tray Amsoil if it is thicker than MT-90.
Purely a bonehead move on my part. I am glad I got on it after only 1 day.
ok... how much did you use for your rear diff? also wat brand? i used redline for the tranny and
bevel and i filled until it leaked out... i didnt hear any noise after i'm done ... tranny is next on my list...seeing that it's easy to do, why not do it
