Check engine light....
P4022, something about a rich gas mixture.
Could this possibly be the problem?
I would clean your maf sensor with some cleaner then clear the code. I just realized, my expensive intake has that hose opened up as well, but i have no codes going. clean it off, and you should be good.
To the OP, The code must have been P0422 - Main Catalyst,Bank1 Below Threshold. Do a search and you'll find lot's of info.
That open tube goes to the SAI (Secondary Air Injection) pump and should have a breather filter or something on it. If something big enough gets in there, well that would suck.
You might want to also check your Coolant Temp Sensor, too.
Just tossing that out there.
Thanks.
F.
Thanks.
F.
