Cluster question
Old Mar 2, 2005 | 05:01 AM
suiTTman's Avatar
Member
Default Cluster question
OK - I'm pretty sure I have a bad cluster.. on 2 recent trips I'd be driving along and all the guages would turn off for a second, then ok for a while then it would happen again....
Sounds like a bad cluster ???
Is there any problem using car until I get a chance to have this fixed ?? any safty issues ??
Thanks
Old Mar 2, 2005 | 05:11 AM
TTinCT's Avatar
Rest In Peace
Default Possibly...could also just be a loose connection on the back of the cluster>>>
although that is not too likely...
Old Mar 2, 2005 | 05:14 AM
OldSchool AG's Avatar
Senior Member
Default This was happening on mine>>
turned out to be a loose connection on the battery negative terminal. Maybe that, or your battery is going?
Or probably just a bad cluster.
Old Mar 2, 2005 | 05:18 AM
TonyStarkz's Avatar
Had that problem exactly...turned out to be a dirty ground from the neg. side of the battery
Old Mar 2, 2005 | 05:22 AM
hAUDIni's Avatar
Member
where you been recently, witness protection?
Old Mar 2, 2005 | 05:25 AM
suiTTman's Avatar
Member
Been real busy working... (seasonal biz)
Old Mar 2, 2005 | 05:27 AM
suiTTman's Avatar
Member
Default Gonna check the connection - could be -->
I had changed the battery (yes by myself) a few months ago... maybe just not tight enough!!
Old Mar 2, 2005 | 05:38 AM
Senior Member
Default Ah-ha! Same as my situation>>
I swapped batteries in the wal-mart parking lot, using only an adjustable wrench, and forgot to check the tightness when I got home. Month or so later the cluster wackiness ensued.
Old Mar 2, 2005 | 09:09 AM
Via911's Avatar
Car Nut
Default Always nice to see you Jay!
Saw the Touareg outside, nice! Now come on, buy the Boxster S for Joyce!
Old Mar 2, 2005 | 09:44 AM
suiTTman's Avatar
Member
Its a pretty Boxster, but dont think so...
revisiTTed
Mar 31, 2008 01:46 PM
Jetace1
Oct 10, 2005 04:21 AM
Jetace1
Aug 7, 2005 04:24 PM
pianogrg3
May 12, 2005 05:29 PM
WGJ
Jun 26, 2000 08:27 AM
