clutch problems
clutch problems
Guys, my beloved grey ttr 2000 late model has an issue with the clutch pedal does not fully return gear engagement is a little notchy is it low fluid if so where to check cannot find any info in the hand book. If its worse new clutch? what costs and where to go need help DESPERATE am leaving for Indonesia for work for 8 months in about a month and need it fixed for wife!
Sounds like the slave cylinder... In order to replace you need to tear down
all the way to the rest of the clutch, so a full replacement is recommended (minor increase in parts cost, same labor, complete new clutch).
Re: Sounds like the slave cylinder... In order to replace you need to tear down
Thanks for the advice hope your wrong $$$$"S BUT I would on balance think your correct many thanks
seencats
02-01-2007 08:43 PM
brian a
Misc. Models Discussion
08-05-2000 09:44 AM
