Combi Valve update.
Combi Valve update.
I went to a dealership and tested (and subsequently purchased) a combi valve. For the record if you are going to test your valve - when you draw vacuum on the port, it should NOT leak out the top small hole. I cannot tell you what the small pin hole is for, except that it will let the vacuum out if the internal diaphram is ripped.
Combi valves seem to go for $150-186.
Cartoondog.
Cartoondog.
