Cv boot problem
So yesterday I was back out of my friends driveway and my lower control arm snapped. When it snapped I believe it pulled the boot off of the cv joint and all of my grease/oil came out. I haven't had a chance to take a look yet and see if the joint is still intact. Assuming the joint is fine how easy is it to just put a new boot on and what kind of grease/oil would I use? Do our cars take a specific? Mine is an 01 TT Quattro 225 btw.
Thanks in advance for help.
You will need a 3/4" drive torque wrench (a torque wrench with 250-300 ft-lbs. capacity)and the proper hex(allen) drive wrench. The inboard CV Joints use 12 point internal drive tools to remove (10mm IIRC) so you'll need that tool as well.
The grease is a molybdenum type for CV Joints. OEM and proper OES CV joint boot kits come with a grease packet. Most will include a new stretch bolt as well. If using OEM from a dealer, you can always buy a stretch bolt if the boot is not part of a service kit.
Thus, depending on your capabilities and tool selection; this could be easy or it could be a royal PITA.
