Diagnostic help?
Diagnostic help?
2001 Audi TT has begun popping up the ABS warning light. It doesn't remain lit long, sometimes next off/on cycle is enough. Here's the log, a sensor near the right front inner fender?
Thanks for any experience with this one.
Tuesday,02,October,2018,14:34:04:38274
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
VCDS Version 18.9.0.2 HEX-NET CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.clb
Control Module Part Number: 8N0 907 379 E
Component and/or Version: ESP 20 CAN V004
Software Coding: 18446
Work Shop Code: WSC 01236
VCID: 3E30F9C738E237BAE7-4AE1
1 Fault Found:
01279 - Longitudinal Acceleration Sensor (G251)
27-10 - Implausible Signal - Intermittent
Who can point me to the right thing what needs fixin'. Above leads me to some sensor? near pass side front fender?
thanks!
Julie
www.Ross-Tech.com
1 Fault Found:
thanks!
Julie
Hi, My 2001 Coupe did that several years ago. If I remember correctly the longitudinal sensor is behind the glove box and accessible by the dash panel end cap. The other one ( lateral) is in the dash panel near the steering column. It’s about a $250 part. It does require vag com to calibrate the signal after replacement. It does reset after each stop start cycle and codes are not visible wants the engine has been turned off and restarted. Lots of info online if you search Audi TT acceleration sensors. Good luck!
