Doh! Door wont open from outside but it opens from inside.. how hard is it to get to the latch..
i was at work and went out for a drive to get some mobil 1 grease for the DV. when i went to open the door at first the latch wouldnt pull out all the way??? needless to say the door didnt open. on the second try i pulled a little harder. now it just pulls out all the way but doesnt open. it does however open from the inside. so iam guessing either the cable got unhinged or some plastic tab broke.
how hard is it to access this part. i dont want to wait to the weekend to fix this. i was thinking of doing it tonite with a flashlight unlesss some one chimes in and warn me that iam about to tackle a 3 hour project.
It's pretty easy to get to the mechanism
<center><img src="http://lz7w.com/albums/doorpull/IMG_2248.jpg"></center><p><ul><li><a href="https://forums.audiworld.com/tt/msgs/1224024.phtml">https://forums.audiworld.com/tt/msgs/1224024.phtml</a</li></ul>
Thanks, I think ill just give it a try here at work while its still day out.
i was just looking at your earlier post on the door handle install. thanks for the assurance. hope fully ill get it fixed before i even go home.
Are talking about the alignment bracket in car itself. if so, i doubt its that because it opens from
the inside just fine. i had to lower the window and use the inside latch to open the door to get in.
It's a bit tricky to do all of this. Chances are this cable came loose.
<img src="http://mk1tt.montebellopark.com/images/latchbar3.jpg">
<img src="http://mk1tt.montebellopark.com/images/latchbar1.jpg">
You will need to remove the door card, and the whole latch assembly to get at this cable
You can of course open the coor card to inspect this before any removal.
Good Luck
Good Luck
