Door Electrical Circuit
I have an 01 tt 225.. I have a problem in the door circuit and I need a wiring diagram to help me figure out where the problem is.
The problem is that sometimes the dome light and map lights wont work. A good bump and sometimes they will work again. Additionally the passenger door lock wont unlock when you push the button on the key. The other thing it does is a good bump while going down the road I can hear a click and the dome light will turn on. It stays on until you flip the switch or the car is turned off again.
Any help figuring this out would be most appreciated.
Or look here
https://www.audiworld.com/forums/tt-...latch-1929857/
Thank you,
I will definitely take a look at that.
James
James
Sounds like your micro switch in the door has gone bad. Search door switch.
Or look here
Or look here
rogeryang56
03-09-2015 04:34 AM
dipset.802
12-20-2010 05:34 AM
