Driver side window issue
Old Apr 29, 2007 | 10:02 AM
element2050's Avatar
New Member
Default Driver side window issue
After lunch on Friday my drivers side window decided to stop working. Passenger window works fine still.
When i click the roll down switch i can hear it make a click over noise like its gonna work but nothing happens. The window does not do the 1/4inch rolldown when you open the door either.
Ne ideas? Thanks!
BTW changed the haldex today thanks to all who said get two bottle first time
Old Apr 29, 2007 | 12:50 PM
BAJITTO's Avatar
Default hey bud, what I would do is take the panel off and see if its binding or if...
your regulator went to ****. I was going to say check for power to the motor but sounds like its getting power since you can hear it trying to work.
Old Apr 29, 2007 | 03:54 PM
panTTera's Avatar
Default When I had that same problem recently,
<center><img src="http://pictureposter.audiworld.com/115012/audiwindowmotor.jpg"></center><p>complete with opening the driver's door while idling and hearing the relay clicking while trying to drop that 1/4 inch, it cost $$$ to buy and $$$ to install one of these,and I got this one to hang on the garage wall.I hope your denim results are better than mine. A regulator would be less $$$, so hope for that- I did!!!
rkarsk
TT (Mk2) Discussion
Jan 22, 2021 02:57 AM
Meegis
Sep 6, 2007 05:55 PM
thtguy
Jul 25, 2003 06:12 PM
kent@thething.org
Dec 7, 2002 06:24 PM
Jack in FL
Misc. Models Discussion
Nov 21, 2000 08:09 AM
