Driver's side Xenon headlight on my TT went dead... then came back to life. What the?
Once again, a strange cryptic looking icon appears on the dashboard warning light zone. A yellow circle with an "X" through it. No circles allowed?
OK, so the daylights fade and soon it is evident that I've got a headlight out. I figured that this could be the bulb or the ballast, hoping it is the first. So I order a bulb.
Today, I turn on my lights and... what? No headlight warning? Yes, it's back. I've got both lights again. Now, I'm concerned. I thought that when a Xenon bulb goes out, it's gone. Do I have a flaky ballast then?
mine took a month to go. it was off and on for awhile...
would turn lights on and get the warning but could switch off and back on and the headlight would work..
got progressively worse - would have to switch off/on a few times for light to work.
.. then it just went dark. permanently.
my bulb came loose in the socket.
and then proceeded to melt the socket. function was intermittent and I replaced the bulb twice before I had to remove the headlight and replace the igniter.
If you call:
-audi, they will sell you a new headlight $$$$
-bosch, the igniter alone is $500
-used, closer to $50.
If you call:
Good to know. I've been having a "headlight jiggle" issue that
has been going on for some time, only noticeable on rough roads. I've brought it up to my dealer on 3 separate occasions when in for servicing and they tell me that they don't see anything wrong--"everything is tight".
Then suddenly one day I notice my headlights (both) are aiming lower. I searched on it and apparently some level controller may have failed. Certainly the jiggling couldn't have helped and maybe this caused the bulb to come loose.
Anyway, the car is going to be traded in... let the dealer discover and deal with these idiotic issues that shouldn't be cropping up in automobiles at this late stage (certainly the Japanese never have these kinds of problems).
mine was/is a bad connector. I can't find anyone that can replace just the plastic
piece on the end that goes into the light socket. Often if you move it back and fourth you will see your light come on, go off, come on, go off etc...
Mine has some corrosion, and every once in awhile when driving down the road it will go out then flicker... as some others have explained here too... Damn florida rain! arg
