Driver's window stops ~2 mm shy of full up
I started hearing wind noise on my driver's side window. I noticed the top of the window is ~1 to 2 mm lower than the passenger side when all the way up. I tried the reset approach of holding the switches up for 5 sec at both upper and lower limits to reset the auto up/down feature, but can't figure out what to reset to get the window all the way up.
Suggestions?
Suggestions?
your car is upset and wants a better exhaust haah..... i had the same issue on my TT...
when i bought my TT the drivers window was adjusted worng and needed to have the regulater readjusted at the dealer to get the glass to seal properlyinto the opeing. wasnt a big deal from waht i saw the tech do.... its been fine ever since.
just pull it up
I had the same thing happen. I just opened the door and with one hand on each side of the window I pulled it up and it has been fine since. There is probably a more 'proper' way of adjusting it, but it worked for me.
Had same issue in cold weather 2 weeks ago. Suggestion >>
Dealer tech tried to tell me about the usual reset, which didn't work despite repeated attempts.
Then I tried it with ignition on but engine off, and it worked. Don't know if this is a typical solution but you could try. Also try with and without the doors open--something I did was magic.
well i dont have the down pipe any more its on its way to CA right now...but
i do have the borla still. im lookin get get 275 for it....... if your interisted let me know.....
