Engine
Old May 20, 1999 | 10:06 PM
Kean
Guest
Posts: n/a
Default Engine
Hola mis amigos. I was wondering if they're going to release a 6 cylindar engine fot the TT in the U.S. Anyone? Thank you.<br>-Kean
Old May 21, 1999 | 07:34 AM
dfs
Guest
Posts: n/a
Default No, but...
A 225hp 4 cyl version available next year will smoke a 6 cyl Boxter.<br>
Old May 21, 1999 | 08:44 PM
Jason
Guest
Posts: n/a
Default Re: Engine
When I went to training for the TT, the instructor mentioned the possibility of a narrow-angle V6(VR6) fitting into the engine bay, but no way on the 2.8 30V.<p>Jason Dale<br>Audi Technician<br>Ken Garff Motors<br>Provo, UT
Old May 21, 1999 | 08:47 PM
Jason
Guest
Posts: n/a
Default Re: No, but...
It will probably smoke the current 201HP Boxster, but not the new one coming soon nor the Boxster S. Then you'll have to do some heavy-duty tuning to keep up.<p>Jason Dale<br>Audi Technician<br>Ken Garff Motors<br>Provo, UT
Old May 23, 1999 | 08:49 AM
Kevin
Guest
Posts: n/a
How does your dealership feel about "chip"ing cars? Does it viod the warranty or not? Also, would you recommend it?<p>Thanks
Old May 23, 1999 | 09:28 AM
Jason Dale
Guest
Posts: n/a
You know, you're putting me on the spot now. I personally do not have a problem with it. Here's some scenarios:1)Customer brings car in with a broken seat-heater switch on a chipped car; there's no problem. 2)Customer brings car in with a water pump leaking on a chipped car-still not a big problem 3)Customer brings car in that boosts about 14PSI and has a bad oxygen sensor-now theres probably a problem.<br>Rule of thumb:try not to advertise the fact that you have modified the car, and if you do get some performance mods: be sure that they are OBDII compliant so they dont set any check engine lights. If you chip the car, make sure that the computer car still talk to the VAG1551 tester at the dealership.<p>Jason Dale<br>Audi Technician<br>Ken Garff Motors<br>Provo, UT
DaBirdman
TT (Mk2) Discussion
May 26, 2018 06:27 PM
Mike Evans
Jul 25, 2015 10:58 AM
MagicTT
9
Jan 30, 2002 01:55 PM
Koushik
Mar 26, 2000 05:33 PM
Joachim Czaja
Jan 20, 1999 01:44 PM
