Engine Bay Pic Request?
Hey guys. Just about done with the rebuild but may have mis placed two of my hoses. There are two hardlines under the strut bar for what I think is Evap and Coolant. Does anyone have a close up of what the lines look like or where they route to so i can make my own? I have everything on the passanger side of the hardlines but the driverside is open. thanks
225? One hard line is very likely a brake booster >
runs from the master cylinder up, to under the strut, to the pass side, then forward to the manifold end. Actually it's in two pieces, connecting near the coolant tank.
Re: Mine...
You can see one of the hard lines under the strut bar in this pic. Kind of looks like it goes to the brake booster or the boost controller. Any close up pics of the lines?? Thanks!
Hey - I don't have a shot of the lines since I have a 180 but >
<center><img src="http://pictureposter.audiworld.com/53277/brake_booster.jpg"></center><p>
I do have the brake booster hard lines I was telling you about in my post below - left over from an FMIC kit; they were never installed. OEM, brand new, w/all the connecting parts shown.
You probably have 1&5 or 2/3&6 - that's the set I have lying around; the other you have/need might be 9 - I don't know, just a guess.
Btw - they sort of "plug in" though, so if you don't have the connector ends, that might be a problem.
AlbaniAudi
03-04-2006 01:10 PM
