First post - Window question
The drivers window does not drop a 1/4" when opening the door as it does on the passenger side therefore it binds on the window seal. I heard about resetting it by lowering and holding 5 seconds then raising and holding for 5 seconds. Is that the extent of reset? The one-touch up or down feature seemed to go away but no change in the lack 1/4" window drop issue.
Any suggestions?
then use the key once more to roll both windows all the way up.
If it is the microswitch, do a search on this forum cuz there is some GREAT advice on how to fix it. (I still need to try it, just TOO busy at work.)
Hope this helps.
Good luck with the window. You got good advice in the other posts. If it is the microswitch in the door latch you can replace that with one from Radio Shack
http://audittmk1.blogspot.com/2009/0...r-fix-diy.html
I read about the microswitch replacement etc so will look into this weekend.
Anything special to get the wheel caps off for changing a tire?
