Fog Light Problem
The **** is pushed in and it does not matter if I push it in or pull the **** out.
HELP!! I am hoping this is a fuse of some sort....
If you know a fellow TTer, you can just try swapping out the whole headlight/dimmer assembly, and see if the problem goes with the assembly. If that works (it works right with someone elses switch assembly), and you don't want to dig into the switch itself, just buy a new headlight switch. Someone here can likely get you the part number, and a link to somewhere to buy it...<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/lighting_systems/foglight_switch_mod/">http://public.fotki.com/mcphill/audi_stuff/lighting_systems/foglight_switch_mod/</a</li></ul>
If Jeff sees this post, I suspect that he could add valuable insight.
