Forge control arm vs KMAC
Anyone used the Forge adjustable control arms instead of the KMAC system. They look like a cleaner solution to me- is their claim they're stronger true or just sales bull#hit?
I have the forge arms I lowered about 1 3/4 "..the arms will allow you to
get camber back into spec but, "might" have a problem with toe adjustment. I did and had to go with the kmac on the bottom as well and all is good now. I hind site a full KMAC kit would have been the best choice and lots less $$, If you don't need the whole kit then you can easily find someone here that needs the other 1/2
I've been considering those Forge arms for several months now....a more elegant solution than....
....KMAC's imho. When I finally do it I'll be sure to document the event. 14000 miles on H&R/Bilstein/25mm spacer combo has taken its toll on the Kumhos.
We have over 500 out there with no problems ..however
If you have some issues please let me know what I can do to help, Now supplying as upgraded product direct to dealers when warrnty replaces original.
The Forge arms are the ONLY ones on the market using Powerflex bushes and with reinforcing arounf the forkend
