Forge Motorsport ECU Data Monitors Now Available....
Forge Motorsport is pleased to announce the latest in automotive diagnostics. The new PSI 3 ECU Data monitor allows real time monitoring of all OBDII based sensors and displays them in a compact, convenient and easy to read display. The unit allows one to monitor up to 4 different parameters simultaneously as well as a plethora of other features. Standard display information includes.
<b>Battery Voltage
Coolant Temp
Engine Speed
Road Speed
Throttle position
Air / Fuel (lambda based or ratio)
Air Flow (CFM)
Intake Air Temperature
Ignition Timing (degrees +/-)
Time of Day.</b>
With the inclusion of additional sensors (sold separately) one can also monitor such parameters as
<b>Boost pressure
Oil Pressure
Oil Temperature
EGT</b>
The unit also includes built in functionality to control a shift light, NOS systems and water injection.
The FORGE MOTORSPORT PSI3 goes several steps further by allowing one to read, and reset all fault codes as they arise. No more going to the dealer to reset your check engine light. The PSI 3 will also monitor, record and store, the following:
<b>Peak Speed
Peak RMPs
Peak Boost (with additional sensor)
Peak Coolant Temp
Peak Oil Temp (with additional sensor)
Peak Oil Pressure (with additional sensor)</b>
A final feature allows the use to pre-set high and low values of certain parameters which will warn the user with via a visual user if peak values are reached as predetermined by the user.
The PSI units are available with 3 different display types. (Military Spec LCD which has a greenish / yellow background and for easy viewing) and a VFD (Vacuum Fluorescent display) which comes in red and blue. Face plate options include real carbon fiber or a gloss black option. Prices start at $539.00 for the LCD display and $659.00 for the VFD displays. There is no additional charge for face options. When you consider that a standard 3 gauge package can run upwards of $350.00 with pods or panels and senders, the PSI3 is a great value considering all of the additional features. Due to the custom nature of the monitors orders will take up to 3 weeks but in most cases you should receive your monitor within 2-weeks of ordering. <img src="http://www.forgemotorsport.co.uk/upload/images/psi1.jpg" border="0">
<img src="http://www.forgemotorsport.com/images/products/FMS1001VVF.jpg" border="0"><ul><li><a href="http://www.forgemotorsport.com/tt.asp?cat=auditt&product=FMS1001VAG">info page.</a></li></ul>
<b>Battery Voltage
Coolant Temp
Engine Speed
Road Speed
Throttle position
Air Flow (CFM)
Time of Day.</b>
<b>Boost pressure
Oil Pressure
Oil Temperature
EGT</b>
<b>Peak Speed
Peak RMPs
Peak Coolant Temp
Can you post some ideas on mounting this thing? I'm having trouble thinking of a good spot for it.
The other possibility (needing research on your part) would be to develop a 'remote' screen for it. That way the main unit could be mounted out of sight somewhere (under the seat, under the lower dash, etc.) and the screen could be mounted somewhere else for better visibility and less bulk. Just thinking out loud...any comments?
