Found.....5lbs?
After doing searches on cold weather boost loss, it seems the concensus opinion is that the ECU dials back boost in colder temps. This is done in order to keep cylinder cranking pressures consistant. Colder ambient temps. mean denser air which requires less boost to achieve the same cranking pressures. Seems to make sense, guess I'll have to wait untill the spring thaw to find out.
There is a known cure for this. Link inside
Read the article. It confirms your findings about mid way down.
Thank Steve for this info as I found it while browsing through his fotki site.<ul><li><a href="http://www.autospeed.com/cms/article.html?&A=0670">http://www.autospeed.com/cms/article.html?&A=0670</a</li></ul> |
And one nice thing about the Boost Machine..>>
Is you can make the seasonal adjustments easily to keep things constant throughout the year. Just turn the regulator 1/2 turn or so......:-)
Love my Boost machine..Just added the Metal works!
<center><img src="http://pictureposter.audiworld.com/62654/ttdaboost.jpg"></center><p>
