Friday night in the garage: Throttle body cleaning
Over the past few weeks, I have been getting a little random stumble at idle even after resetting the ECU (by disconnecting the neg battery cable for a few minutes); replacing coolant temp sensor; running Techron in a few tanks of gas; changing brands of gas; changing spark plugs (what else can I throw at this?).
So I finally had DanoTT talk to our tech at the dealership who suggested since my car has somewhat high miles (75K), I might pull the throttle body and see what it looks like, it might need cleaning. It takes some special cleaner (of course) that cost $4.77 (whew!) from the Audi parts department. Well, here are the pictures, I'm thinking it needs a little cleaning! Dan is bringing over the cleaner - I'll post "after" pictures when I'm done. Intake hose disconnected, throttle body still on car: <img src="http://images15.fotki.com/v266/photos/4/41970/1982850/throttlebody002-vi.jpg"> Throttle body removed from car - look at all that gunk! <img src="http://images15.fotki.com/v263/photos/4/41970/1982850/throttlebody010-vi.jpg"> |
Ick!
Time to flush the system with drano, right?
? will a momentary disconnect of the bat'ry NOT clear the ecu maps?
Sand.....I couldn't find the link to the infamous post
Did you say Dano?.......LoL....>>
Have fun tonight!
hmm... i'm about at the same mileage - should check mine. hope you got a new gasket too!
that looks almost as bad as mine on the eurovan.
After pics - nice and clean now!
And a short test drive was good - I'll report back if the stumble at idle continues (again, it's very random, but drives me crazy).
<img src="http://images15.fotki.com/v266/photos/4/41970/1982850/throttlebody025-vi.jpg"> <img src="http://images15.fotki.com/v267/photos/4/41970/1982850/throttlebody024-vi.jpg"> Here's the stuff used to clean it - according to Dan, there is some type of plastic micro coating (?) on the throttle plate that regular carb cleaner can damage. So use this stuff: <img src="http://images15.fotki.com/v263/photos/4/41970/1982850/throttlebody027-vi.jpg"> |
Much better...>>!
But now you guys need a cleaning...:-)
