fuel fuel fuel fuel.....I need...more....fuel.........
I think :) Does anyone know if Block 001(or was it 002) accurate enough to see if the injectors are maxed out? what ms does it have to be to mean I'm maxed out and need new injectors? Anyone know?
What injectors are you running? If they are 225 injectors...
you can always go to a 4 bar FPR to flow similar to a 440 green top on 3 bar.
Currently still the 180s. And still using the 3bar FPR. I have order the new set of 225...
I just want to know if the injectors will max out. And if so, how can I tell? When my friend used a standalone system, the ms for his car was 100ms and anything past that is basically means I need new injectors. Is that true for block 002?
I don't know about which meas block, but you might find this page helpful...
<ul><li><a href="http://clam.rutgers.edu/~dreadsct//resell/1.8T_injectors.htm">injectors</a></li></ul>
I'm not sure... but I definitely wouldn't run it at LEAST without a 4 bar FPR on those injectors...
or the 225 injectors.
Block 002 will do it, ms depends on rpm, spreadsheet on VWVortex.
