Good Morning All
Good Morning All
Since I have an 180hp TT the driver side opening behind the mesh is completely blocked off. I did an search using different words combo but couldn't find anything on unblocking the mesh in order to install cold air inlets. I do remember some discussion about this but was unable to locate that post. My question is will it do any harm do to unblock this mesh?
TIA Ken
TIA Ken
Morning - no harm - this is the place you want to feed an intake - High Pressure, cool air >
<center><img src="http://pictureposter.audiworld.com/30405/dscn1628.jpg"></center><p>After you install a FMIC, it looks just like a 180 ;-P
Thanks, I know my TTDA will enjoy the fresh air
just been holding off because it was blocked. I saw that those with a 225 were running their inlets to this location and actually looks like it will be an easy install. I got some extra tubing from Steve in order to complete this mod.
Thanks again
Ken
Thanks again
Ken
Get Steve's "Cooler Air" kit! (edit - link added)
<center><img src="http://pictureposter.audiworld.com/102688/vtda_hoses.jpg"></center><p>
Two hoses worth of cooler air for your TTDA or VTDA...<ul><li><a href="http://public.fotki.com/ttschwing/new!_vtda_productio/fresh_air_feeds/">Steve's fresh air feed kits</a></li></ul>
Dremel out, drill out, or chisel out. If me, I would.....
go for drilling each one out and then placing grill over a rounded surface and using a sharp chisel, just whack out the remaining bits.
Thanks but I have a front lip spoiler so I have the opening but the
<center><img src="http://pictureposter.audiworld.com/95165/img_0244.jpg"></center><p>
mesh has a soild piece behind it which blocks air flow. I can remove the mesh and see if the I can also removed the backing.
Thanks again
Ken
Thanks again
Ken
